Soft Reaper
Hi, i've just recieved my optimus X 15" yesterday and have seen critical temps on the CPU (30°c inside my flat, more than 86°c on CPU and heavy throttle even with cooling pad ...) and tried a bit of undervolt. As long as Throttlestop is not an official tool, i'd gave a try to Intel eXtreme Tuning Utility, such a big mistake ...
It asked me for a reboot after applying a 0.5GHz underclock on each turbo state, 95mv undervolt on IA Cores and Cache and reducing IccMax to normal value of 51.3 (set by default to 128A by XTU) and it ended by:
- Disabled Turbo (so max 2.6GHz on all core instead of 3.5 set and 4 default)
- 15w nominal TDP (so 2.6GHz become 2GHz and less)
- 30w Boost TDP (but no boost active)
- But stills 128A on IccMax
And unable to set thing back as XTU thinks it is his "defaults" values, each reboot lead to this and even using hwinfo on windows PE (so another OS) leads to the same numbers, tried to uninstall XTU, reset bios to default values, removing CMOS battery and doing a bios flashback.
The lonely thing i didn't done for now is a intel ME Region reflash (as i think XTU saved theses infos directly in MEFW)
any advice, tip or help would be really appreciated
Thank you by advance
