So much lagg!!!!
Jack Guinea
Every game i try i play im getting continuous lagg even when on the minimum graphic settings, im hoping its just because my pc is really dusty but if not what else could it be?
tom_gr7
Life Serving
what kinda temps do you have mate?
latest drivers? beta drivers? may be worth doing as fresh gpu driver install.
Pagey
Open her up and check your dust levels. Can never hurt to give it a blast out.
How long have you had the PC and when was the last time it was cleaned?
And fwiw, I recently fixed a PC that wouldn't even post by giving it a bloody good clean out. XD
Jack Guinea
Well just from where im sitting i can see dust clogging up the dust filter and fans, im hopefully getting some compressed air tomorrow and then after ive dusted and cleaned it ill report back.
Jack Guinea
Right ive just finished cleaning my computer and its spotless, thing is my games are still lagging. For example on spec ops the line on the menu its fine but as soon as i move my mouse it laggs, i cant even run garrys mod on the lowest setting because it laggs to much.
Wozza63
Biblical Poster
Its either because the intel graphics are running or the GPUs are at idle clock (least likely)
It may be running on intel graphics because the card may not be seated properly try reseating them and see if they are recognised, if not, it may be something to do with the SLI, take one out and try that
Wozza63
Biblical Poster
Turn off the computer, unplug the computer at the back,unscrew the graphics card on the left (hold the card as it may fall) just pull it out of the socket and push it back in firmly and put the screw back in, make sure you ground yourself first, and once you've done one, do it to the other one and then turn it back on and post results
Have you fiddled with any BIOS settings or settings within a certain program that may have changed something?
Jack Guinea
I just did what you told me and when only 1 monitor is activated its fine but when all 3 are acitvated even when only playing on one it laggs uncontrollably.
Wozza63
Biblical Poster
Open Nvidia control panel, go to 3D Settings, and make sure Multi display performance mode is activated under Multi display/mixed GPU acceleration
Did you by any chance download nvidia inspector? its a program that im using to fix the clocks with more than one monitor
Wozza63
Biblical Poster
Ok so here is something you can try on nvidia inspector
open up the program, right click on the show overclock button
another window should open up, tick 'run multi display power saver at startup' then tick both of your GPUs on the right
then slide the left slider to about 30% and run a demanding game, see if that works, bear in mind you will need to adjust this value depending on what game you play otherwise it will keep changing clocks etc during game causing lag, for a less demanding game, decrease this value, for a more demanding game, increase it
I have had one bug when it changes clock speeds through this program and that is that on my second monitor I get a black flash across the bottom of my second screen, barely noticeable really but just thought id let you know, its not caused me any problems particularly
Doing this will also save power as the cards will be at their idle speed when browsing etc, because nvidia drivers seem to autoclock to maximum permanently when you have more than one screen
Sorry this is long winded but hopefully it can fix your problem
Jack Guinea
Not even that has worked, i started up spec ops on 30% and just moving the mouse made it lagged so i bumped it up and it still did it until i had it on 100% and it still did it then, i even tried it on lower % aswell but nothing :(
Wozza63
Biblical Poster
hmm go to the main window right click on the same button and choose the sensors one, make sure the GPU clock is on there, what does it say now? and what does it say when in a game? (you may want to run the game on one screen so you can see the sensor window)
Jack Guinea
I whent in game and as soon as it started lagging i quickly tabbed and took this picture:
Jack Guinea
I dont understand because i was playing gmod with my mates fine and then the next day it just laggs so badly its unplayable.
