So it come to this.................
alexoo
So after messing up my other post with my crappy specs, I have decided chose from 2 specs.
The pc will be used for gaming 2-6 hours per day depending how I feel(Normally I am gaming mood). I need it to run games such as call of duty at
max settings for the next couple of years or so. As I said in the old post.
Here are the specs for both of them.(They are kind of the same but different processor)
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
AMD PHENOM II X4 QUAD CORE 970 (3.50GHz/8MB CACHE/AM3)
ASUS® M5A99X EVO:USB 3.0, SATA 6.0Gb/s, Quad CrossFireX™/SLI™
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
STANDARD AMD CPU COOLER
Quantity 1
ASUS® P8H67-M: M-ATX, DDR3, USB 2.0, SATA 6.0Gb/s, CrossFireX™
INTEL SOCKET LGA1155 STANDARD CPU COOLER
Quantity 1
So which on is best?
Petchi b
Either spec would be fine. The GPU you have chosen is very good so that will keep you happily gaming for a few years. As for the CPU's, not as important for gaming although, Intel do have the edge but any quad core CPU will have no problems. Depends on your budget and preference really.
Whichever spec you choose I would consider these changes;
- Some sort of CPU cooling (tripple copper or Fenrir will suffice)
- 650W Corsair PSU (More reliable and efficient)
- Caviar Black HDD (A lot faster, will give you a much more efficient system)
- Silver warranty for a fiver! (A must!)
One last thing, will you be interested in adding another 570 in the future (SLI)? If so you will have to upgrade the motherboard if you choose the Intel spec. Similarly, if your answer is no you could downgrade the motherboard on the AMD spec to the M5A87 and save a bit of cash.
Petchi b
This is the spec I would go for with your budget. It's a shame there are no tripple copper coolers available for AMD builds as that would put you under £900.
ASUS® M5A87: AM3+ PLATFORM, DUAL DDR3,SATA 6.0GB/s, USB 3.0
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Price: £908.00 including VAT and delivery.
