SLI Bridge
MrVex98
Hello guys.
Just wanted to ask if I buy a build with two cards. What kind of SLI bridge does come with it? Is it the Nvidia HB one?
MrVex98
Thank You. If You already here, I'd like to ask you what monitor would you recommend me for 4K gaming? Some curved one would be good. With g-sync, IPS and HDR max 27 inches. Any suggestions?
I went for X34A which is not 4k but between 1440p and 4k. You could consider Acer 32" XB321HK for 4K.
What's your budget? An entry level 4K gaming monitor is around £400 but if you're looking at anything other than a TN panel, this begins to skyrocket.
MrVex98
Alright guys. So I can spend £800 on monitor. So, any suggestions? It would be good to have 144hz. I was using 17"3 laptop screen before so I think the 27" wouldn't be too small? But I played only in 1080
What gpu are you getting? I don't think there are 4k 144hz available for sale yet
MrVex98
I haven't thought about it yet but if you could of suggest some nice pc build for 3-4K£ it could be interesting. I'd like some 4K capable pc
If you wish to have a SLI gtx 1080 ti aircooled that would be around £2600. If you want something silent during gaming and can spend +£3400 then an option is a liquid cooled system but requires maintenance every 2 years.
