sli 780 build
Bsrz
Rising Star
Hey all, any Thoughts or suggestions about this build? - its designed for triple monitor gaming at max resolutions, running the latest games.
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Intel® Core™i7 Quad Core Processor i7-3770K (3.5GHz) 8MB Cache
3GB NVIDIA GEFORCE GTX 780 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW) -------- might swap this with a 2tb hdd once I compare the boot times in games and apps.
CORSAIR 850W PRO SERIES™ HX850-80 PLUS® GOLD MODULAR (£139)
INTEL SOCKET LGA1155 STANDARD CPU COOLER ---------------------------------------------- this will be removed and replaced by a noctua nh-d14
ASUS Xonar D2X - Masterpiece Audio Card for Home Theater (£82)
Price: £2,577.00 including VAT and delivery.
Bsrz
Rising Star
ah I should have mentioned I need the 16gb for video editing, but swapping the ssd for a hdd will save a few hundred in turn allowing me to get the platinum warranty. thanks Keynes
Blackdog
Looks like a solid build and in other news I am very jealous and hate you. Please let me know what the noctua cooler is like as I am considering one myself.
Bsrz
Rising Star
thanks and will do, just need to make sure I get the right one for my processor as I have heard one dosent support the 3770k
Boozad
I was looking at the NH-D14 a while ago and meant to buy one to go into my new build, then completely forgot. Hmmm, maybe a bit of amending going on soon.
tom_gr7
Life Serving
the D14 is mint! Noctua are really good too. easy to install, great cooling, quiet.... but quite big... can get an extra set of fan clips from Noctua for free, if you want to add a third fan...
can always change the fans like i did.
Buy it now!
tom_gr7
Life Serving
How quiet is it Tom?
its pretty quiet, but i dont use the noctua fans. Which is one problem with the cooler. The fans are older 3 pin fans, so if you were to get it. I would strongly suggest getting two-three new PWM 4pin fans, of a decent brand. But this isnt 100% needed as the 3pin fans are good enough.
there are other large air coolers that do perform pretty well, such as bequiet, planteks, or silver arrow coolers.
