Single or Dual Link
Topher
Afternoon all,
Just a question I have ordered a new build that includes a 2GB GTX 770. I have seen on here that some people have had difficulties with the DVI ports on the PCS 770's
Can anyone let me know if the 770's that PCS put in their builds are single link(18 pins) or dual link (24 pins) DVI connections so I can make sure I have the right connection type on my cable
Cheers
Chris ;)
Rakk
The Awesome
They should be dual-link connections as far as I can tell, one will be a DVI-I, one will be a DVI-D (meaning you cant connect an analogue connection (ie VGA) to the DVI-D port cos it wont work) - though to be honest I thought all the DVI ports on the newer cards would be dual-link connections anyway.
To be honest I haven't really seen any complaints about the DVI ports on an GTX770
