Showing spec
BE QUIET! DARK BASE PRO 900 REV. 2 FULL TOWER GAMING CASE
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
12GB ASUS ROG STRIX GEFORCE RTX 3080 Ti - HDMI, DP, LHR
8TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
1TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6000MB/W)
Braided Power Supply Cables
CORSAIR Premium Individually Sleeved PSU Cable Kit Pro - Red
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler
3x Corsair LL120 RGB LED Fan + Controller Kit
ASUS STRIX Raid DLX 7.1 PCIe sound card
What's it being used for, what's the budget, what are monitor specs (resolution & refresh rate, or make and model), also can you post the configuration link
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/zbxhf4e0Pq/
samsung galaxy g7 monitor its gonna be used for gaming and home working mostly.
MrWilson
Made a few changes.
FRACTAL DEFINE 7 BLACK QUIET MID-TOWER CASE Really solid and quiet case. It's what I have and I can highly recommend it. The Be Quiet is really expensive and I can't endorse it.
AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4) The 5950x is more geared towards productivity and actually does slightly worse than the 5900x in some games.
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP, LHR STRIX variant is OOS, there is very little difference but you can amend to this when it's back in stock
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE Lowered HDD storage. If you need that much storage consider a NAS.
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW) Games will barely load faster off the Firecuda so can save a little here.
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler Ample cooling, extra fans won't be neccessary.
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Platinum Warranty isn't really worth it, most faults will happen in the first year. Your purchase though, so definitely an option if you want piece of mind
Price: £3,614.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/nWd4esct9U/
Made a few changes.
Thank you for the recommendations problem I have already put in the order so probably over done it with the parts of some of them the graphics card is generally what they had in stock so just had to go with what they had I'm assuming my build wont be much of a problem just acase of me over spending when I didn't need to per say but thanks for the post.
MrWilson
You can make amendments for free up until it goes into build :)
JUNI0R
ill see if I can as its on finance so not sure. Is the graphics card a problem though don't exactly know the OOS term
I believe you just pay or get a credit note for the difference in price so the finance is unaffected. OOS just means out of stock.
The one comment I’d make is that the Fractal Define on the build has a solid side panel (not a glass one), and Wilson has specced the Capellix with the LCD which you won’t be able to see. I’d either purchase a glass side panel separately, or I’d swap to the non LCD version (y)
Cheers for the infomation ill try and edit stuff when it allows me to as its still processing the OOS on the graphics card wasn't present when I made the purchase so they might have took it off afterwards after my purchase?
