MrVideoFreak
The max temps seem very high, should I be concerned? I have 4 case fans, and the PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler
Can you post your full specs from the order page?Mainly the RAM, but also the CPU and Hot Spot for the GPU
Case | PCS PRISM TG WHITE ARGB MID TOWER CASE |
Promotional Item | Get Marvel's Midnight Suns with select GeForce RTX 30 Series GPUs! |
Processor (CPU) | Intel® Core™ i5 10-Core Processor i5-12600K (3.7GHz) 20MB Cache |
Motherboard | ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready |
Memory (RAM) | 64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB) |
Graphics Card | 8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR |
1st M.2 SSD Drive | 512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW) |
1st Storage Drive | 2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 750W RMe SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET |
Power Cable | 1 x 1.5 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING |
Sound Card | Asus Xonar AE 7.1-Channel Gaming Audio Card |
Network Card | 10/100/1000 GIGABIT LAN PORT |
Wireless Network Card | NOT REQUIRED |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
Operating System | Windows 10 Home 64 Bit - inc. Single Licence |
Quick test is to run the PC with the side off the case for about 10 minutes and then do another screengrab of the temps to compare.
Case PCS PRISM TG WHITE ARGB MID TOWER CASE Promotional Item Get Marvel's Midnight Suns with select GeForce RTX 30 Series GPUs! Processor (CPU) Intel® Core™ i5 10-Core Processor i5-12600K (3.7GHz) 20MB Cache Motherboard ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready Memory (RAM) 64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB) Graphics Card 8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR 1st M.2 SSD Drive 512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW) 1st Storage Drive 2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE DVD/BLU-RAY Drive NOT REQUIRED Power Supply CORSAIR 750W RMe SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Power Cable 1 x 1.5 Metre UK Power Cable (Kettle Lead) Processor Cooling PCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler Thermal Paste STANDARD THERMAL PASTE FOR SUFFICIENT COOLING Sound Card Asus Xonar AE 7.1-Channel Gaming Audio Card Network Card 10/100/1000 GIGABIT LAN PORT Wireless Network Card NOT REQUIRED USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS Operating System Windows 10 Home 64 Bit - inc. Single Licence
