Serve mw well for gaming?
markdienekes
Intel® Core™i5 Quad Core Processor i5-4690K (3.5GHz) 6MB Cache
InWIN GT1 BLACK GAMING CASE
ASUS® Z97-PRO GAMER: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
Free Item: FREE BATMAN: ARKHAM KNIGHT Game with Select GTX 9 Series GPUs!
1st Hard Disk
500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
Super Quiet Titan DragonFlyTriple Copper Heatpipe Intel CPU Cooler (£19)
Will this serve me well enough for gaming?
1st Hard Disk
do you have a budget?
markdienekes
That's around my budget- I posted a while back with a smaller budget, but now this is probably the most I can spend... Hopefuly can upgrade it bit by bit in future :)
if you post your budget someone could come up with an alternative, slightly better system.
Intel® Core™i5 Quad Core Processor i5-4590 (3.3GHz) 6MB Cache
ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
Free Item
1st Hard Disk
250GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Price: £872.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/ErFuhRcMeZ/
markdienekes
Just one more question - which case do you think is better?
The one I chose above, or this one?
CORSAIR SPEC-03 COMPACT GAMING CASE
markdienekes
Heya, just one more question, I was just wondering how upgradable this setup would be? Would it be easily doable if I were to throw an i7 in a year or two? Or RAM? Thanks for your time once again!
Fantana
The H81M-PLUS motherboard has 2 DDR3 slots so I think the most RAM you can have is 16GB
Also it only has one PCIe slot, so you can't have a second GPU if you ever consider SLI.
You can upgrade the CPU to i7 no problem.
Thanks mate, and the motherboard can be easily switched at some point too I take it?
Yes, but its quite a big job, you have to dismantle the whole pc and rebuild it, a motherboard upgrade is something you only want to do once a new architecture is out.
