Screw size
I have a 15.6" Notebook NL51CU. A few screws are missing and 2 are very difficult to remove from the bottom of the chassis, I daren't put them back in in case of not being able to remove them again.
Hopefully it's a simple one for you all, but anyone have any idea what size screws I'd require?
Thanks in advance.
Bhuna50
Very small :D
Your best bet would be to give PCS a call and ask them directly - you never know they might even send you some if you ask nicely LOL
Thanks Bhuna50. I've messaged Tech Support but I'll try that.... Failing that I'll just take it to a pc shop andbuy screws from there if they have any.(y)
