Last March i purchased my PC from here, And now i want to upgrade my memory.
Is Samsung Hyper-x 1600 still available? Not sure what the CL, RTC... etc are.
According to one of your previous threads you have
Kingston Hyper-X Genesis Dual-DDR3 1600MHz X.M.P (2 x 4GB KIT)
If so, I think it's still available,best give PCS a call.
oh then you have been given the wrong ones, you didnt need to take it out you could have seen just by opening the side, its a pretty easy mistake and im sure they'll sort it for you, heck they may send you another set and not bother asking for the others back seeing as RAM is pretty cheap, then if you overclock the samsungs or underclock the kingstons, you could have 16gb, i recommend underclocking as there is no benefit to overclocking the RAM and will ruin the lifetime warranty, besides the kingston will usually work at 1333mhz normally, mine was originally but then i changed it
When i got my system, I thought that Kingston was installed so used X.M.P. to take the memory up to 1600. I looked on the net and managed to find a couple of post's which stated that overclocking to 1600 without lowering the voltage can damage the CPU.
Now i'm really stressed, Not only was the wrong memory fitted, But what little information i was able to find, Suggest's CPU damage could occur. I've now dropped the speed to 1333.
Can anyone give me more info on this?
