Samsung G5 27" Alternatives
OliverBarnes742
I've ordered my first PC last week and I was recommended the Samsung G5 monitor to go with it by a few mates and some people on this forum. I've looked on lots of sites and can't find any in stock anywhere, are there any good alternatives for the same sort of price? Or does anyone know where there are G5's available? Here's my specs below if needed, thanks in advance :)
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
Standard Build - Approximately 20 to 22 working days
OliverBarnes742
The next best option at that budget would be the AOC or the gigabyte (gigabyte being much higher end):
Gigabyte G27QC 27" Curved VA QHD (2560x1440) 165 Hz FreeSync Compatible Gaming Monitor, Black https://www.amazon.co.uk/dp/B08BXKS...abc_397MY0FC5RK5B2HCFJ8F?_encoding=UTF8&psc=1
Appreciate that, both within my budget :) What makes the Gigabyte the better buy over the AOC just out of interest?
TBH, nothing on paper.... but I'd expect the panel to be a higher caliber.
AOC are budget, they're very good at budget options, but they do have to sacrifice some bells and whistles to get there. The Gigabyte is a low cost mid range screen, it's just higher quality.
OliverBarnes742
Thank you for that, appreciate the advice :) 👍🏼
There's a really in depth review of the gigabyte here:
If you skip to the summary, he actually constrasts the Gigabyte with that AOC model, and summarises that actually, for the increased cost, the gigabyte isn't worth it over the AOC.
So basically ignore my last comment ;)
Bobjones522
Argos had some G5s in stock when I looked about 5 days ago. I ended up ordering the G7 from them though.
