SAM ACTIVATED?
ChaAli
Hi
Anybody have a clue on how to check if SAM is activated. Asked PC specialist to arrange this.
Many thanks
Hi
Many thanks
There's an article here on it:
Be aware, don't update your BIOS without PCS authorisation as it may affect your warranty.
It should be on the latest BIOS, but just worth mentioning.
A short way to check is as follows:
  1. Go to Device Manager
  2. Under display adapters, right click on your GPU
  3. Click properties
  4. Go to the resources tab and make sure that Large Memory Range is there.
If that is listed - then you should be good to go!
