Sales advice
Hi, can you tell me if this is a good build and I am mainly going to be using this for gaming. Also can you please tell me if the components are suitable for each other. Also are there any alterations i might need to do?
Thank you.
PCS SPECTRUM RGB MID TOWER CASE
AMD Ryzen 7 2700 Eight Core CPU (3.2GHz-4.1GHz/20MB CACHE/AM4)
8GB AMD RADEON™ RX 590 - HDMI, DP - DX® 12
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
2nd Storage Drive
STANDARD AMD CPU COOLER
Hi there,
What is your budget and which monitor are you looking to pair the system with? Do you know the model number or the resolution/refresh rate?
