Ryzen 5900x High Temps
Stubee
Hi I received my new pc yesterday and everything is great just haven't got around to posting any pictures yet but I am having an issue with my CPU temps and my fans ramping up to almost 100% because of it just from some light gaming, everything is fine idle.
Here are my specs:
COOLERMASTER MASTERCASE H500M GAMING CASE
2nd M.2 SSD Drive
LED Lighting
50cm RGB LED Strip
Standard Build - Approximately 18 to 21 working days
Promotional Item
Get Battlefield 2042 with select GeForce RTX™ 30 Series GPUs
Welcome Book
Logo Branding
PCSpecialist Logo
Stubee
You need to find which fan / fans it is that's running fast, then we can target it to workout why.
I think I have fixed the issue, took all the panels off my case and had a look at all the fans and they seemed fine so I decided to tighten the screws which seemed to help the noise almost like the screws were not in tight enough and was causing some sort of noise issue, I will update in the next few days on how it is, thanks.
Have you downloaded and installed AI suite3, in there you'll find a program called fan expert 4 which you can use to control the fans as explained in this video:
