Hey guys,
I've emailed PCSpecialist about this directly but thought I'd post here as well and see if anyone's got any ideas.
I got my PC a couple days ago and it's running great except I'm slightly concerned about some of the temperatures I'm seeing.
I was on the phone to one their tech support employees yesterday (who was very helpful) who ran a stress test with temperatures maxing out at around 78 degrees C which is a bit higher than I was anticipating but they told me it was fine and there should be no problems. That's fine but I'm also slightly concerned about the temps I'm getting while idle or under small loads.
When I open up the bios settings the CPU temp sits at around 50 degrees which is quite high I think for completely idle in the bios. It seems to spike up to around 60-65 degrees under the smallest amount of load. When playing a game under around 20-30% load the temps were creeping up to 75 degrees C. When the temperatures get that high the fans start getting quite loud which is disappointing considering I'm supposed to have ultra quiet fans. Additionally with a 240mm cooler (and based on some research) it seems like the temperatures shouldn't be as high as they are.
I can hear a small bit of clicking from the pump which hasn't disappeared over the past few days which I'm slightly concerned about as well.
What steps can I take to troubleshoot and fix this issue?
Full Spec:
CORSAIR iCUE 465X RGB GAMING CASE
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
Insurance
Simplesurance Purchase Protection inc. Accidental Damage & Theft
Standard Build - Approximately 15 to 18 working days
Promotional Item
Get CoD:Cold War with select RTX Graphics Cards
Welcome Book
Logo Branding
PCSpecialist Logo
Full Spec:
Insurance
Promotional Item
Welcome Book
Logo Branding
PCSpecialist Logo
