films&games
When I experienced the AMI bios 1 long + 3 short beeps, I have decided to run Memtest86. I downloaded it from the official website Memtest86.com and created a bootable USB stick. I ran Memtest86 without changing any config options, I just clicked on Start Test. I have not touched the RAM itself since I have had my PC.
Memtest86 has so far finished 3 passes out of 4 and there are no errors shown.
There are two Memtest86 versions: Memtest86 and Memtest86+ both are free. Which is the one to use or are they similar?
If Memtest86 completes all 4 passes and there are no errors found - Should I also run Windows Memory Diagnostics in Extended mode as well?
Progress update: Memtest86 has now completed all of the tests (4 passes) and it's shown no errors. This is with both RAM sticks still installed at the same time.
Any advice or suggestions would be appreciated, please.
Thank you.
Thank you.
