I think it's about time to replace the machine I got from PC Specialist about seven years ago - I've been waiting for the Ampere announcement before putting in an order, and I'm still trying to figure out what the best way to order this machine is, since it seems I can't pre-order the Ampere cards, so perhaps I will order for the rig to be built without a graphics card initially?
My intention is to have an RTX 3090 in this for gaming and AI training, and I also want to use it for rendering and running simulations. I've gotten a little used to having my workstation from work while working from home the past few months, and being able to use its 24 cores and 96GB of RAM, so I'd quite like to put together something with similar performance that I can use at home for the next few years.
This is my first time switching over from Intel to AMD - from what I can tell, this seems like the best value option? I've had mixed experiences with Intel CPUs and I've heard good things about Ryzen.
Also unsure about the best case for this build - I'd prefer something that's well-enclosed and has as few lights as possible. I liked my old Stormtrooper case for that (and it's nice carrying handle), but the rubberised coating has gone to hell on it, so I don't want to reuse it. Pretty much all the available cases for this build have glass panels on them, which I'm not hyped about. If possible, would like to keep the machine relatively quiet.
Edited with improved case/cooling.
FRACTAL DEFINE 7 XL BLACK QUIET TOWER CASE
AMD Ryzen Threadripper 3970X 32 Core CPU (3.7GHz - 4.5GHz, 147MB CACHE)
ASUS® ROG STRIX TRX40-E GAMING (DDR4, Wi-Fi 6, CrossFireX/SLI) - ARGB Ready!
64GB Corsair VENGEANCE DDR4 3600MHz (8 x 8GB)
16TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
Corsair H150i PRO Hydro Series High Performance CPU Cooler
Standard Build - Approximately 14 to 16 working days
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-trx40-pc/cQPPN9Heyw/
