RTX 3080 - wow a little blurry
Peaceful123
Hi all.
Just got a new pc from pcspecialist.
Operating System: Windows 10 Home, 64-bit
DirectX version: 12.0
GPU processor: NVIDIA GeForce RTX 3080
Driver version: 516.59
Driver Type: DCH
Direct3D feature level: 12_1
CUDA Cores: 8704
Resizable BAR Yes
Core clock: 1710 MHz
Memory data rate: 19.00 Gbps
Memory interface: 320-bit
Memory bandwidth: 760.08 GB/s
Total available graphics memory: 18338 MB
Dedicated video memory: 10240 MB GDDR6X
System video memory: 0 MB
Shared system memory: 8098 MB
Video BIOS version: 94.02.71.40.72
IRQ: Not used
Bus: PCI Express x16 Gen4
Device Id: 10DE 2216 161219DA
Part Number: G132 0031
Turned wow on and the game is a little blurry. Kind of washed out. Do I need to do anything with the nvidia 3D settings? I'm sure I am doing something wrong!
Thank you for any help.
Hi all.
Driver Type: DCH
CUDA Cores: 8704
Resizable BAR Yes
IRQ: Not used
Hiya, could you post your full specs from the order page?
Also, what make and model monitor are you using?
Peaceful123
Hi
COOLERMASTER MASTERBOX K500 ARGB GAMING CASE - ESL
Processor (CPU)Intel® Core™ i7 12-Core Processor i7-12700KF (3.6GHz) 25MB Cache
MotherboardASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
Memory (RAM)16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP, LHR
1st M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Power SupplyCORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable1 x 1.5 Metre UK Power Cable (Kettle Lead)
Processor CoolingPCS FrostFlow 120 Series ARGB High Performance Liquid Cooler
Operating SystemWindows 11 Home 64 Bit - inc. Single Licence [KUK-00003]
Asus Monitor
ASUS VG278Q, 27 Inch FHD (1980 x 1080) eSport Gaming monitor, 1 ms, Up to 144Hz, DP, HDMI, DVI, FreeSync, Low Blue Light, Flicker Free, TUV Certified, Black​
Thank you x
Hi
Asus Monitor
Thank you x
Sorry to say but that monitor is completely wasted on that PC, totally pointless.
It's going to look dreadful because you've got a top tier GPU on an entry level poor quality monitor.
It's not the PC that's at fault, the monitor is the bottleneck.
RichLan564
Monitor isn't that bad though? Still shouldn't be blurry though should it on the panels native resolution? A 3080 will drive 1920x1080 or 1024x768 if it comes to it just fine
Monitor isn't that bad though? Still shouldn't be blurry though should it? A 3080 will drive 1920x1080 or 1024x768 if it comes to it just fine
1080p is blurry by the exact nature of it. Because the pixel density is so low. That's why it's so cheap and easy to drive and over 20 years old now.
You can see by the included screenshot that it's nothing to do with the image output from the GPU, but related to the monitor display.
But even if it looked incredibly sharp, it would still be an absolute waste of a GPU for that monitor and would still be unsuitable. The advice would still be that it was wasting a good spec PC.
RichLan564
I know exactly what you are saying but 1920x1080 isn't *that* bad, from that screenshot it looks more like the game settings are wrong as the fonts for one don't look right which is normally a give away for something not setup correctly.
To conclude I agree a better monitor would be the way to go for sure.
I completely disagree, entirely in every way.
1080p should be avoided at any cost and only embarked on if severe budget restrictions dictate it.
It looks dreadful.
But as I said, I wouldn't spend the time troubleshooting it, that's kind of my point because even if there is something amiss, it's still a pointless monitor to pair with that hardware, just doesn't fit, you're gonna miss out on most of the performance available on the PC. Just wasting cash.
Get a decent monitor, then re evaluate.
B4zookaw
In the meantime, check your ClearType settings in windows and confirm WoW graphic settings are set to run in 1080 resolution
RichLan564
It looks dreadful.
We agree to disagree then in that case ;)
moosEh
Administrator
Staff member
Could you take a picture of your monitor in wow rather than a screenshot as (although its been a while since I last played wow) it seems to be as i remember it from your screenshot.
stegor
I use 1080p and it's fine. Not blurry at all and I'm at 27 inches so it aint small either. OK so my eyes aren't as good as they were but no way can you see pixels, even close up. I think you have a faulty monitor.
