RTX 2080 fans revving up all of a sudden.
Dear all,
On of the fans on my graphic card (RTX 2080) started acting up about a month ago.
For some reason, as soon as the GPU temperature reaches 78°, the fan starts spinning at full speed (3680 rpm) and makes a lot of noise. I don't understand why (see picture in attachment) . I'm no expert n the filed, but 78°C doesn't seem terrible as far as high end GPU temperatures go.
This is very annoying as I spent quite a lot of money on this desktop computer to make as quiet as possible.
Before you ask, my graphic card drivers are up to date.
How can I fix this issue? Any help would be greatly appreciated!
PC SPECS
CaseBOÎTIER MOYEN TOUR FRACTAL DEFINE R6 NOIR SILENCIEUX
Processor (CPU)Processeur Eight Core Intel® Core™ i9-9900K (3,6 GHz) 16 Mo de cache
MotherboardGigabyte Z390 AORUS PRO: ATX, LG1151, USB 3.1, SATA 6 Go/s - Compatible RGB
Memory (RAM)16 Go Corsair VENGEANCE DDR4 3200 MHz (2 x 8 Go)
Graphics Card8 Go NVIDIA GEFORCE RTX 2080 - HDMI, 3 DP - Compatible GeForce RTX VR !
1st Storage DriveSSD 1 To Samsung 860 EVO 2,5 pouces, SATA 6 Go/s (jusqu'à 550 Mo/sR | 520 Mo/sW)
1st M.2 SSD Drive512 Go SAMSUNG 970 PRO M.2, PCIe NVMe (jusqu'à 3500 Mo/R, 2300 Mo/W)
DVD/BLU-RAY DriveGRAVEUR DVD DOUBLE COUCHE 24x ±R/±RW/RAM
Power SupplyCORSAIR 1200W HX SERIES™ MODULAIRE 80 PLUS® PLATINUM, ULTRA-SILENCIEUX
Power Cable1 câble d'alimentation suisse, 1 m (C13/C14)
Processor Cooling: Corsair H115i PRO Cooler w/ PCS Ultra Quiet Fans
Thermal PasteCOOLER MASTER MASTERGEL MAKER PÂTE THERMIQUE
Sound CardHIGH DEF AUDIO (EN STANDARD) 6 CANAUX (5.1) INTÉGRÉ
Wireless/Wired NetworkingPORT 10/100/1000 GIGABIT LAN (Wi-Fi NON INCLUS)
USB/Thunderbolt OptionsMIN. 2 PORTS USB 3.0 ET 2 PORTS USB 2.0 SUR PANNEAU ARRIÈRE + MIN. 2 PORTS EN FAÇADE
Often the built in fan profiles are quite agressive to keep cooling down as much as possible.
You can set a custom fan profile with MSI Afterburner:
or EVGA Precision X1:
I installed AFTERBURNER but it didn't make any difference. I tested different fan speed curves but to no avail. As soon as my GPU hits the 78°C temperature mark, one of the fans immediately goes into jet turbine mode. (see the screenshot in attachment).
What's also strange here is that only the tachometer registers an increase in fan speed. The "fan speed in %"graph doesn't change.
I must also insist that everything was fine for almost a year. This problem is recent. I'm not the only one who's having this issue. Other users have also noticed an absurd increase in fan speed when reaching the exact same temperature mark (78°) --> https://forum-en.msi.com/index.php?topic=322601.0
What else can I do?
You can set a custom fan profile with something like
What else can I do?
in that case I’d raise it with PCS, sounds like that card may have an issue.
