RTX 2060 OR GTX 1660Ti?
Rather than posting about each component, if you post your full build, what you’re using it for and what monitor you’re pairing it with then we can comment.
+1 to the above. Please post a budget and prospective spec.
You were asking earlier about the Crosshair mobo. Buying a Crosshair mobo and an R5 CPU would probably be bonkers. (Bonkers in general, and also with Zen 2 expected to launch literally in a few days!)
You should post the full spec you are considering, and a budget, for feedback.
