I was thinking for a laptop! cant decide between the cheaper optimus 4 with i5-3230m and gtx660m or vortex 3 with i7-3630QM and 7970m but for an alot higher price
well, I would suggest atleast a quad core and the strongest gpu you can afford. But that's easy for me to say, it depends on how much you are willing spend.
Vortex Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-3630QM (2.40GHz) 6MB (would I be better off going for one of the dual cores (but with four logical cores) and with higher clock speeds?
8GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (2 x 4GB) (surely enough?)
AMD® Radeon® HD 7970M - 2GB DDR5 Video RAM - DirectX® 11 (i presume its better then the gtx 675mx??)
Memory - Hard Disk
500GB SEAGATE HYBRID SSHD Drive, SATA 6 Gb/s, 64MB CACHE (5400 rpm) (is it worth the extra money over a 500GB scorpio black??)
Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® N135 802.11N (150Mbps) + BLUETOOTH
