RGB only working on Corsair H115i pump head but not fans
Scarno
Hey, as title says. Not the most pressing issue but any help would be appreciated.
Just got new build today. The pump head shows up in iCUE and I can change the RGB on that but there's no RGB on the fans. The fans aren't showing up under the lighting effects in iCUE for me to be able to change them. Under the performance tab, I can see the fan speeds for both Fan #1 and #2 so iCUE at least seems to recognise them there. Fans are spinning, just no RGB. I've updated iCUE but no luck.
Looking around online for help, most people in forums are talking about Commander Pro or Lighting Node Pro. Do you need those to have RGB on fans? Or might this be a hardware / cable issue?
Processor Cooler: Corsair H115i RGB PRO XT Hydro Series High Performance CPU Cooler
Motherboard: ASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Case: COOLERMASTER MASTERCASE H500M GAMING CASE
The cooler you have selected isn't the RGB Platinum one. The fans don't light up on the XT.
