RGB LED Strip
calvej6
Hey,
I have ordered one RGB strip with mu build. Is there away to chagne this to a static colour or is it constant RGB? im not sure how its connected or where to control it, if that is the case.
Anyone know? :)
Thanks.
It's usually via a piece of software, like Armoury Crate. If you can paste your whole system spec over, we can advise accordingly.
calvej6
Thanks AgentCooper - here it is.
CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
LED Lighting
2x 50cm RGB LED Strip
Firefox™
Standard Build - Approximately 15 to 17 working days
Promotional Item
Get 1-Year Founders Membership to GeForce Now w/ select RTX Cards
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/0yv4gdaPMf/
I have the same motherboard and yes, it’s definitely Armoury Crate from Asus you’ll need to download for that one 👍
You should be able to vary lighting colours and effects, including the little bit of RGB that’s on the motherboard itself.
calvej6
Brilliant, that was also my second question regarding the motherboard RGB lighting. Thank you very much AgentCooper I will download that :)
