Rgb keyboard
marn
I got this notebook for school so i can code on it however it seemed slow therefore i reset it but lost the rgb keyboard control centre and i am not able to change my leds and or the brightness of it. As well as this i have lost the program that allowed me to modify my speakers as i have the Sound Blaster Pro Gaming speaker. Can yo please the link the programs that i need to download in order to get these back.
If you log into your main PCS account and go to the downloads section, all your drivers are in there.
i tried this but nothing is in my downloads
Did you buy it from PCS?
If there’s nothing in your downloads then you need to contact them directly and get your account setup.
If you didn’t buy directly through PCS then you need to register the machine with them.
phitol
What model is it? As PCS laptops are based on a few manufacturers, if you give us the model, we might be able to point you in the right direction.
Note also, if using the latest Windows 10, I did a 'reset' last week and lost the Sound Blaster Connect App, In the end I downloaded the full Windows re-installation ISO (I believe you can do this using the "microsoft recovery media creator windows 10" and did a fresh install. This brought back the Sound Blaster App and all the latest drivers.
All I really ended up doing was downloading the Clevo Control Centre (as mine is based on a clevo chassis) direct from Clevo themselves to give me Keyboard RGB, Fan Control and power modes (Performance, Quiet, Power Saving, Entertainment).
