RGB Keyboard flickers
InTheMood
Hey,
I bought a new laptop about two months ago, as follow:
Defiance Series: 15.6" Matte Full HD 240Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 11800H (2.3GHz, 4.6GHz Turbo)
16GB Corsair 3200MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 3060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
AC Adaptor
1 x 180W AC Adaptor
2 x Defiance Series Battery Pack (One Spare, Requires Assembly)
1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
15" DEFIANCE SERIES UK KEYBOARD
It is running the default W10 install.
Tonight, I noticed that the RGB keyboard LEDs are flickering a bit, especially whilst fading up and fading out. Being plugged in or on battery makes no difference, and the issue is clearly noticeable at night.
I have noticed for the first time tonight but it could have started anytime before. Looks a bit like a power issue to me, what do you think? I'm not really sure what other steps I can take in regards to this, it's a 1.5k+ laptop so I'd rather it behaved properly.
Here is a video I hope shows the issue clearly!
Thank you
Hey,
AC Adaptor
1 x 180W AC Adaptor
Thank you
It's unclear as you haven't posted the full specs, did you pay for windows or install your own copy?
InTheMood
Ah! I had ordered without Windows but in the end activated the test version it came with.
Then, I installed all drivers packaged on my account online. Didn't have any issues with anything else.
Do you think I need to install a fresh Windows?
You can't use the test version as it's not configured. You need to do a full clean install.
InTheMood
Damn! Interesting. I also thought this originally but Windows official wording lets you think otherwise, it pretty much says verbatim that you can simply activate the test version and it will self configure as a regular Windows install.
Ok so; can I just install any official Windows 10 image on there? And then I just need to install all drivers? Or is there another process?
Also; is there a way for me to reinstall a fresh Windows and use a backup of my current install to reinstall all the apps and documents?
You use the latest image from Microsoft. It's just a normal clean install.
You can't backup programs, windows doesn't work like that. All your data will be on a separate drive so there's no need to touch that. You only need to format the c drive.
InTheMood
Cool! Can you confirm if I need to install all PCS drivers after the clean install?
I should say the keyboard flicker happens before the laptop boots into windows as well... Are you still edging towards a faulty W10 install?
The windows installation isn't faulty, it's just not configured as there's no need to for testing.
If you've ordered without windows it's understood you know how to configure it yourself.
Apologies, I'm sure someone else may give instructions.
InTheMood
'Configure' is a very vague term in that scenario.
Fine, I'll give it a go later and report back if it fixed it. I'm still thinking it has more to do with a power issue in the chassis though.
Until youre on a stable windows we can't do any troubleshooting as the software isn't correct.
InTheMood
Hey! I've just reinstalled a fresh copy of Windows! I've done my windows update and downloaded control centre 3.0 from Windows Store.
The issue is sadly still present... Any ideas for troubleshooting?
InTheMood
Me again! Discovered a new issue with the headphone jack output on the laptop, which makes a very audible click occasionally... Might be related? I've installed the clevo audio drivers and SBX on the fresh Windows but no luck.
Can you take a screenshot of your windows update and optional updates pages?
InTheMood
For sure.
InTheMood
I see where you are going with this, and I had a look before posting here; no unknown device, yellow triangle and the audio devices are detected as it should.
I'll send a pic later today and I can even send a recording of the click, but I am doubting the software trouble as it is and think it has more something to do with power in the motherboard, as per my OP
