SuperMeggido
Review of the Optimus V 15.6” from PC Specialist
Date: 12/02/14
After doing much research and 'lurking' for 9+ months I have settled on this. I needed a gaming laptop as well as a portable essay machine, this the reason being that I chose the 15 inch version and not the 17 inch version. I chose PC Specialist because of the pricing as well as the customer support, as I didn't want to buy something for £1000 and then not have competent people helping me with future issues. I am writing this review 4+ months from when I received the laptop in October 2013:
Optimus Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4700MQ (2.40GHz) 6MB
16GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (2 x 8GB)
Changed: Originally ordered only one stick of 8GB, later ordered another 8GB stick from PCS and installed myself
NVIDIA® GeForce® GTX 765M - 2.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
240GB INTEL® 530 SERIES SSD, SATA 6 Gb/s (upto 540 MB/sR |490MB/sW)
Changed: Originally ordered only HDD, later ordered SSD from Amazon and installed myself
6x BLURAY ROM, 8x DVD ±R/±RW & CYBERLINK SOFTWARE
Bluetooth & Wireless
GIGABIT LAN & KILLER™ 1103 WIRELESS GAMING 802.11N NETWORK CARD
Optimus Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor
Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence
OPTIMUS SERIES UK KEYBOARD WITH NUMBER PAD
Dead Pixel Guarantee
Intel Anti-Theft Technology
Free 90 Day Intel Anti-Theft Trial - Prevent Data Access Upon Theft
Insurance
Total
£980
Total including changes
£1204
The PC Specialist website was easy to navigate and I soon was configuring my future laptop/pc with over the top components. After some research and forum reading I became familiar with the components and what I would need. My need being to play PC games at 1080p on Medium graphic settings or higher, at 30 frames per second or higher, as well as a machine light/sturdy/small enough to be carried around outside for 10+ hrs. In addition I have bought separately a Kone XTD mouse (£60), Steel Series 4HD gaming mouse mat (£20), Qpad QH-90 PC gaming headset (£95) and two Coolermaster Notepal U3 laptop coolers (3 fans each) (£25 each) to be used with the laptop. For backup of the hard drives I bought a 1TB WD My Passport Slim (£75) external hard drive with USB 3.0 connection. All were bought from Amazon but if you shop around you can probably find them cheaper, as I bought most of them last summer.
Accessories (not bought from PC Specialist)
The mouse is very nice, having customisable LEDs on it and a smooth matte texture. It is suitable for palm grip and finger tip grip users and can even accommodate small - medium hands (like mine). The shape is ergonomic meaning it is designed to be comfortable so you can use it for extended periods and still avoid discomfort, and it's tracking is also very sharp and reliable (depending on what DPI settings you put it on). From their website you can download a program for the mouse to even customise it further, and included with the mouse are four 5g weights for your preference.
The mouse mat is especially made for laser mice, as it has 'mirrors' on it's surface for faster and more accurate tracking. While it is not necessary for laser mice, as they pretty much can handle most surfaces very well, it will make that difference for those using mice in a professional or demanding way (animation, gaming etc.). Beware according to reviews the special 'mirror' coating does wear off with use, having had mine now for 7+ months I have not had a decrease in performance yet.
The QH-90 headset are really nice too, while not the best in surround sound or having the biggest base they have a really clear and very well balanced sound. Special mention must be given to the build quality and comfort level as you would be hard pressed to find something in the same price or lower as comfortable or sturdy as this headset.
The laptop coolers are comprised of a metal stand that slopes upwards with about 6cm height from the desk on the far end. It comes in different sizes (U1,U2 and U3) but despite the description given for the U3 and the U2, the U2 will be too small for the Optimus V 15 inch and so if bought with the Optimus V 15 inch in mind it is imperative that you buy the U3. The difference between this cooler and others is that is has three small fans instead of one giant fan, that that you can attach on the underside of the stand (using the grate like surface of the stand) so you can optimise and prioritise airflow and cooling. Having 6 fans (from two coolers) I put one on the HDD, one on the battery and the other 4 in a line for openings of the cover of the laptop and the SSD (see Pictures).
The 1TB hard drive is well protected in it's metal casing (which also aids to keep the hard drive cool as the heat dissipates faster) and using a USB 3.0 connection will transfer data very quickly. The case has a little white LED that will flash to indicate that the hard drive is in use and you might heard a faint noise from it, but not louder than your own hard drive in the laptop.
These are not full reviews but merely a quick guide with opinions, before you buy any of these you should make sure that they are the right choice for you by looking at other people's professional and amateur reviews/opinions (except that bit about the U3/U2).
Ordering, Packaging and Installation
When I ordered the above spec with 5 day fast track, the screen and processor were not in stock and I had to wait two additional weeks (in total 2 and a half weeks including fast track) for the laptop to be dispatched and delivered to me with a refund for the fast track. It was built by Jonathon Brown, tested and QC'd by Ben Wilson and packed by Anthony Cunliffe who all did an awesome job. The laptop has not developed or had any faults yet (besides the 'VGA' button that is unimportant to me and not working correctly). When it dispatched I got a text from DPD detailing in which hour slot they would arrive the next day.
When it arrived in the morning in it's huge box I was reassured that it did not suffer any damages on the way, as the packaging as well as the way it held the laptop were very secure. Everything was in a plastic bag of it's own, and there were coverings for the screen and lid of the laptop to prevent scratches from occurring. Unfortunately I do not have pictures of the unboxing or packaging, as I had all but a very low resolution phone camera then so I thought it wouldn’t be worth it. The laptop was not damaged or scratched in any way on the way as far as my naked eye could distinguish, maybe a microscope would beg to differ.
Once I put the battery in and plugged it into a socket I turned the laptop on and preceded to install windows and any drivers/programs. At some point the installation asked for a windows key which usually is a sticker somewhere on the laptop, but I could neither find it on the laptop or anywhere else in the box. I contacted PC Specialist and after explaining to them the situation and sending them a picture of the back of the laptop as proof that I did not have my key, I received a picture of the sticker (so I could enter the key immediately) and the next day the sticker arrived in the post. I was pleased as to how swiftly this issue was dealt with and continued my installation.
I was supplied with all the necessary drivers by PC Specialist on a CD marked with a sticker, detailing which Windows copy it was for and my laptop chassis model. Installation of the drivers was self explanatory, as once the program on the CD started you just had to click onto the drivers in the numbered order they were listed to install each of them. The only driver that was missing/not working was the one for USB 3.0. At this point I left it as the ports were working fine on USB 2.0 and I planned to reinstall everything anyway when I got my SSD. After the windows installation and the driver installation was complete I connected to the internet to download and install the windows updates.
Date: 12/02/14
Memory - Hard Disk
Insurance
Total
£980
£1204
