Requesting Help for a New PC Spec.
Foxx744
Due to my machine (purchased late 2019) being non-upgradable to Win 11, I am taking this opportunity to purchase a new PC. I have a budget of around £2000. I am looking for a PC than can cope with reasonable high end gaming and a motherboard capable of upgrading its components (CPU/Graphics Card etc). I am a fan of onboard drives (Currently 2 x M.2 SSD). I have 3 monitors attached to my graphics card (4 Ports total). I would greatly appreciate some direction on suitable PC spec/s for me to investigate further. Thank you in advance.
You only have one gaming monitor currently which is 1080p, that's going to bottleneck any modern system at this budget. You really need to consider a 1440p monitor.
In what way would it become a bottleneck?
It's too low resolution, the GPU wouldn't be able to perform at it's capability.
1080p is a dead resolution, 1440p is the new standard. And it's such a vast improvement, there's really no reason to limit yourself to 1080p anymore. Things have moved on substantially in the last 5 years.
Nursemorph
I've done a spec which, admittedly, is a bit over the budget. Some provisos:
GPU: I don't know what, if any, AMD GPUs are incoming...I know the NVIDIA 5070 is coming but no clue on it's pricing
Drives: No clue what your drive capacity is but I figure you can use your old M.2s as storage/games drive/s
Windows: Left it out as you can transfer your W10 licence to your new PC, install W10 then do an in-place free upgrade to W11.
CORSAIR FRAME 4000D RS ARGB MODULAR
GIGABYTE X870 EAGLE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair VENGEANCE RGB DDR5 6000MHz CL36 (2 x 16GB)
20GB GIGABYTE RADEON™ RX 7900 XT GAMING OC - 2 x HDMI, 2 x DP
CORSAIR 1200W HXi SERIES™ MODULAR 80 PLUS® PLATINUM V2
CORSAIR ICUE LINK TITAN 240 RX LCD RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £2,128.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/JrPG2raCQc/
Foxx744
Microsoft® Edge
I'm curious - How do you transfer a Win 10 License to a new PC that doesn't have an operating system?
Nursemorph
You makes sure that it has been tied to your Microsoft account then simply install WIndows on your new machine and sign in with the same MS account. This thread covers the process:
Foxx744
Thank you, good to know.
Foxx744
I If I transfer my Win 10 License to a new machine, does my old machine cease to function?
