removing thermal paste
Hello,
Jut a quick question, I want to take old thermal paste from a CPU. Would ethanol be ok? Got some from the college lab.
Cheers,
Ruben
Buzz
Master
Its best if it has a very high % of alcohol. I think some say 70% or higher is best. That or use something like ArctiClean
Personally id go with the bought stuff as thats what its designed for. I have heard of people melting parts of the board using the wrong stuff. Also if going with Alcohol personal opinion id go even higher then a 70% concentrate
I was told by the lab technician is 95% (i think), any recommendation on what to use? Qtips or cloth?
adahil
I bought a special thermal paste removing kit, and it works a treat. One to remove the paste, one to prime the surface for new paste to be added. I think it was the one for_the_buzz suggested.
I used a cotton wool pub (as in the ones you clean your ears with, lol!) for the sides and fiddly places.
Thanks for the feedback, I know the one you refer to adahil. I just want to get a new cooler fitted straight away and it would take days for me to get the removal paste delivered. The old thermal paste is just placed in the center of the cpu, I was thinking of using q-tips but as suggested by for_the_buzz a cloth may be more appropriate, perhaps the microfibre cloth that comes with monitors to clean the screen.
tom_gr7
Life Serving
if you use alcohol, make sure you only apply a drop or two, n make sure it doesn't run on the mobo,
the articlean stuff smells like oranges by the way : )
Corfate
Seriously, the nicest smelling oranges i've ever smelt. I could get high off it!
I used kitchen roll for mine :)
Ethanol worked really well, the paste came off pretty quickly and I use the microfibre cloth that came with my monitor.
