Remade GF gaming Corner
loso64
I just spent good 4 hours remaking my girlfriends gaming corner. This is the end result, with new shelves, new light system, new zelda lamp. , and proper cable management (it was literal spider web before).
There is also a small USB hub installed around sitting position, so she can plug 3 more usb devices easily, like a cable for charging her headphones or usb stick etc.
There is tiny bit of messy cables on the right, because those cables need to be unpluggable and bit loose as the table can be raised to standing position.
Hopefully i can get @AgentCooper seal of approval for cable management :D
loso64
That zelda lamp is awesome where did you get it from ?
there exists official zelda lamp product, however it is very hard to get as i think it was limited. On top of that it is made of very cheap plastic materials.
This one is a wooden replica handmade and i bought it from Etsy. It was about twice the price of the official one and took a good month and half to arrive from US due to covid restrictions, but it was worth it.
