Jamesben832
I'm getting 16gb of ram in a laptop I'm configuring but I can't decide whether to pay extra for hyperX impact, does it make a noticeable difference in performance and does it last longer? All info will be helpful- thanks.
Depends on how much extra it is and exactly what you intend on doing with the laptop. For most uses I would say no - you won't notice the difference between 'normal' and 'faster' ram.
If its not much more, maybe get it and if you ever do anything that warrants the extra speed its there. If its a fair amount more then I wouldn't bother.
Yeah, it's actually £30 exactly so probably won't go for it, thanks for the advice£35 extra? Definitely not worth it in my opinion.
Unless you want to overclock the memory, the manufacturer is completely unimportant - just get the cheapest RAM.
