EmmaWilliamson688
HI guys, i got my pc and I've been using it for a week now and i love it but i noticed my gpu bracket is pretty much just sitting under the gpu with nothing to hold it up which is odd. I see online most have something that is a slider of sorts that holds it and the bracket is not against the card. If the fans spin up as a result they rattle a bit so I've had to bolster it up a bit under the cables with a spare rubber grommet. Its a rog strix 3090
Can anyone recommend a good support bracket for this card?
