Recoil
Paul1964
I thought they were TongFang.
Recommend you go for the AMD CPU as this time round it's better than the Intel option.
The Recoil name is just PCS current branding of their top tier, the chassis make can well change between years depending on what’s better from that years offerings.
So the 16” 5070ti has the following model number
AIstone X6FR57TY
The last number letter sequence will change depending on GPU selected.
I would definitely go for an AMD chassis given the choice
Sam MG
I see that 96GB Ram option is no longer there for 16" AMD Recoil. Any ideas why? Non-compatible / out of stock?
It means that it is currently out of stock.
