gh2k
I posted about this in the Linux forum as I initially thought it was Linux-related, but I've since discovered that it isn't so I'm starting a new thread here.
I have a brand new Recoil II. When I use it, the fans do not change speed automatically. I can run 'game center' and change the fan speed manually using the 'turbo' option or dragging the fan slider in 'business mode'. However, under normal operation or when set to 'gaming mode' the fans do not adjust speed at all.
When the computer turns on the fans spin up whilst the BIOS is loading, but then turn down to a slow speed. Once the O/S is running they stay low, even if running Prime95.
Additionally, when running Prime95 the CPU clock rate drops to quite a low level. This occurs even if I turn the fans to 'turbo' in Game Center. See attached screenshot:
The physical turbo button itself doesn't do anything.
I've installed all the drivers from my download page for this laptop after reinstalling Windows. On a fresh Windows install without Game Center the fans do not turn on at all (or turn on to their minimum level and I can't hear them.)
I'd like to try resetting the EC, and also the BIOS, but I can't figure out how to do this so would take suggestions. I also saw someone mention that they'd undervolted their CPU but I can't see any CPU voltage settings in the BIOS. The settings seem limited mostly to UEFI options... Is there an advanced page that I'm missing?
Any other ideas?
Any other ideas?
