Recoil 5900HX RTX 3070
rarghrhead
Hi just did a quick preliminary configuration after seeing the availability of the new ryzens. I was eagerly awaiting for the new Legion 5 Pro but wonder if you guys have any thoughts with how this compares particularly against the legion 5 pro's 5800H (45watt) + RTX 3070 (140watt boost). Will the 3070 on the recoil configuration see similar power boosts?
- Also I have a spare Windows 10 license but am wondering how do I go about getting required software/drivers for this machine if I don't select an operating system.
- Does this chasis allow access to upgrade or swap the CPU/GPU/RAM/SSD? and if so does it void the warranty? I think the system can handle a faster ram (3200mhz) but from the selection available falls under (3000mhz). These are mainly upgrades I will do down the line in 2 or 3 years. I also have my own tubes of mx4 thermal paste I could apply.
- Is there a mux switch? switch between using dedicated graphics and the cpu integrated one.
- Is the screen comparible with the legion 5 pro of 500nits brightness and accurate colour reproduction?
- Any idea of cpu + gpu temperatures under sustained stress/loads?
my specs are
Recoil Series: 15.6" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
AMD Ryzen™ 9 Eight Core Processor 5900HX (3.3GHz, 4.6GHz Turbo)
32GB Corsair 2933MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
Get 6 Months Founders Membership to GeForce Now w/ select RTX 30 Series Laptops
Get Outriders with qualifying GeForce RTX Powered Laptops
AC Adaptor
1 x 230W AC Adaptor
Recoil Series Integrated 94WH Lithium Ion Battery
Bluetooth & Wireless
1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
PER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD
NO RECOVERY MEDIA REQUIRED
Firefox™
Notebook Mouse
INTEGRATED 1MP HD WEBCAM
