solidus1983
Hi my laptop has arrived from PCS, Firstly lovely packing by the people at PCS and great job performed by the builder.
I have noticed in the Welcome pack there is some what look to be 3mm 1.5mm/1.0mm thermal pads i take it this is for the M.2.
There is also a screw that has what seems to be two nuts on either end not sure what that is for so hence my question.
SPEC
SPEC
Chassis & Display Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080) + G-Sync
Processor (CPU) Intel® Core™ i5 Six Core Processor i5-11400 (2.6GHz) 12MB Cache Memory
(RAM) 4GB Corsair 2133MHz SODIMM DDR4 (1 x 4GB)
Graphics Card NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive 128GB ADATA SX6000 LITE M.2 2280 (1800 MB/R, 1200 MB/W)
Memory Card Reader Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor 2 x 280W AC Adaptor Power Cable 2 x 1 Metre UK Power Cable (Kettle Lead)
Battery Recoil Series Detachable 8 Cell Lithium Ion Battery (97WH)
Sound Card 2 Channel High Def. Audio + SoundBlaster™ Atlas & Super X-Fi
Bluetooth & Wireless GIGABIT LAN & KILLER™ Wi-Fi 6 AX1650 M.2 GAMING + BLUETOOTH 5.0
USB/Thunderbolt Options 2 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
