I'm close to pulling the trigger on a 5900HX/3070 Recoil 15 and had a few questions.
Cheers
- Whats the BIOS and command centre software like? Do all Tongfang resellers get the same BIOS/command centre software and updates?
- Does the BIOS have XMP? I was thinking of using 3200mhz RAM as only 2933mhz is available from PCS. I know its not a huge difference in terms of real world performance but I have some leftover.
- How loud is the mechanical keyboard? I'd like to use it in class/library and am worried about the noise levels.
- Is there a MUX switch to disable Optimus?
Cheers
