Wondering if anyone can point me in the direction of a fix.
After working perfectly since delivery, the audio output jack now outputs a reduced right channel volume.
Tried uninstalling the driver but it just reappears when I plugin headphones.
Checked my ears by swapping headphones round, issue persists. Connected speakers and get the same issue.
Connected headphones via Bluetooth and problem disappears, reconnect headphones in the audio jack and the problem reappears.
As this PC is primarily used for audio production this is a big issue.
It seems other people have had similar issues:
I've also tried swearing at it. That didn't help.
RealTek HD Audio balance issue - Windows 10 Support
RealTek HD Audio balance issue - posted in Windows 10 Support: Hi all, I recently conducted a fresh install of Windows 10 and for the first few days the audio seemed to be working fine. However, for reasons unknown to me this changed and I found that I could not hear the audio from university...
www.bleepingcomputer.com
Is there a permanent fix for Realtek left/right balance bug Win10? - Windows 10 Help Forums
I am using an older Asus Maximus VI motherboard with built-in sound using Realtek tech. Since upgrading to Windows 10 a few years ago, I have an on-going bug where my left / right balance will favour the left side. The balance is set to equal. The only wo
www.tenforums.com
Elimina Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080) | |
Processor (CPU) | Intel® Core™ i7 Eight Core Processor 10870H (2.2GHz, 5.0GHz Turbo) |
Memory (RAM) | 16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB) |
Graphics Card | NVIDIA® GeForce® RTX 3060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1 |
1st Storage Drive | NOT REQUIRED |
1st M.2 SSD Drive | 1TB INTEL® 665p M.2 NVMe PCIe SSD (up to 2000MB/sR | 1925MB/sW) |
Memory Card Reader | Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC) |
AC Adaptor | 1 x 180W AC Adaptor |
Power Cable | 1 x 1 Metre Cloverleaf UK Power Cable |
Battery | Elimina Series Detachable Lithium Ion Battery |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING |
Sound Card | 2 Channel High Def. Audio + SoundBlaster™ Cinema |
Bluetooth & Wireless | GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0 |
USB/Thunderbolt Options | 1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT |
