re quote
vanthus
Member Resting in Peace
like jack im not caring about playing games at full throttle,so ive changed processor from 6 to 4 core,& ram from 8 to 4gb.also changed case,i see people telling him to change graphics card from 1GB ATI RADEON™ HD 5850 PCI EXPRESS to gtx 460,ive read on other sites yould be crazy to do this as the 5850 is better than even the gtx 465.so i would really appreciate some advice from you guys (or girls)
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB ATI RADEON™ HD 5850 PCI EXPRESS - DirectX® 11
2nd Graphics Card
NONE
40GB Intel® X25-V 2.5" SSD (34nm / upto 170MB/sR | 35MB/sW)
3rd Hard Disk
640GB WD CAVIAR GREEN WD6400AARS, SATA 3 Gb/s, 64MB CACHE
RAID
NONE
10x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£89)
2nd DVD/BLU-RAY Drive
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
CORSAIR 650W PSU (TX650) 80+ ULTRA QUIET (£76)
Sound Blaster® X-Fi™ Titanium PCI Express (£66)
ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem
NONE, I WILL BE USING BROADBAND
Floppy Disk Drive
NONE
Firewire & Video Editing
3 Port IEEE 1394a Firewire PCI Card (£9)
TV Card
HAUPPAUGE HI-DEF SATELITTE DVB-S2 TV RECIEVER (WinTV-NOVA-HD-S2)
Monitor
NONE
2nd Monitor
NONE
DVI Cable
NONE
GeForce 3D Vision
NONE
NONE
Mouse
Logitech® MX™518 Optical Gaming Mouse (£29)
Speakers
LOGITECH Z323 2.1 Stereo speakers with Rich bass and 360-degree sound (£39)
NONE
Headsets (VOIP)
Logitech® PC Headset 860 Stereo with in-line volume control (£15)
Surge Protection
Belkin 8-Socket 2M SurgeMaster with £175,000 Protection Warranty! (£18)
Printer
NONE
External Hard Drive
NONE
Home Installation
NONE
Data Recovery
NONE
price £1324.:confused:
Sleinous
if you want, you can downgrade the HDD to the 3gb/s WD10EARS (still 64mb cache) just runs at 3gb/s. But, anyway, HDDs dont ever operate at 6gb/s due to their relatively slow access times in relation to an SSD. yes, you do see a minute speed increase, but only in certain read write tasks :) So, really not worth it. the 3gb/s one is identical, just a green one, for power saving and obviously 3gb/s data transfer speed.
I notice you went for the 640GB 3gb/s drive too. Maybe you could now get 2x 1TB WD10EARS as you will save a little on the WD1002FAEX :)
CPU Cooler is fine, CPU is fine too. Graphics card is your choice. What the reviews often forget about is the CUDA technology you get with a GTX 460. So in some respects it would always thrash a 5850 at certain tasks. For example, video conversion through Badaboom using the CUDA tech (note that atm Badaboom doesnt support the 400 series GPus but it will at some point).
Sensible choice on the Samsung RAM.
Hope that helps.
vanthus
thanks for that sleinous,what do you think of changing processor from 6 to 4 core,sure makes some difference in the price.
Sleinous
Unless you're running some specialist programs that can make full use of 6 cores. E.g. folding@home or programming of some sort, 4 cores is more than enough :)
PCS
Administrator
Staff member
Great spec you've put together there, but do you really need ther extra DVD Writer drive? You Blu-ray writer can write DVD's too, and so unless you plan to regurarly copy DVD's directly from disc to disc, there's no real requirement for this (one drive can still copy and discs).
About the HD5850 - many of our forum emmbers are Nvidia fans and therefore recommend the GTX460/465 over Radeon cards, but you're correct in saying that the 5850 is a higher performing card in most benchmarks.
vanthus
glad you brought that up about dvd drives,im just not sure if the blueray drive can handle dual layer.
vanthus
just one more thing before i order,about usbs,ive had conflicting advice from pcspecialist,if i get 2 port usb 3.0 internal pci card will i still have usbs as standard,i just want to have usb3 option,but not at expense of losing all the usbs as standard as one guy has told me,hope that makes sense.also thanks to sleinous about the hard drives im going to go with that,just need an answer about the dual layer capabilities of the blueray drive.then i think im ready to go.
Sleinous
I do recall enquiring about dual layer on bd drives and am near 100% certain Pcs said yes. But still, triple check. No u wont lose the other usbs as they are all soldered onto the motherboard and face out the backplate + the frontal ones :)
PCS
Administrator
Staff member
To confirm, the current (20/09/10) Blu-ray re-writer drives do support dual layer DVD writing/reading. The current model is LG BH10LS30 with the following specifications:
BD Read Speed 10X
BD-R Read Speed 6X
BD-RE Read Speed 8X
BD-R Write Speed 6X
BD-RE Write Speed 2X
BD-RE DL Write Speed 2X
DVD-ROM Read Speed 12X
DVD-R Read Speed 16X
DVD+R Read Speed 16X
DVD-RW Read Speed 12X
DVD+RW Read Speed 12X
DVD-RAM Read Speed 12X
DVD-R Dual Layer Read Speed 12X
DVD+R Dual Layer Read Speed 12X
DVD-R Write Speed 16X
DVD+R Write Speed 16X
DVD-RW Write Speed 6X
DVD+RW Write Speed 8X
DVD-RAM Write Speed 12X
DVD +R Dual Layer Write Speed 8X
DVD -R Dual Layer Write Speed 8X
CD-ROM Read Speed 48X
CD-R Read Speed 48X
CD-RW Read Speed 40X
CD-R Write Speed 48X
CD-RW Write Speed 24X
