Random Pump Failure's & Game Crashes
Marksy68
Hi All
First post on here and id like to say im not the most technical minded to be honest. Ive had this PC about 4 months. Ive been on and off with PCS regarding it but trying to avoid 1. Removing parts myself & 2. Sending it back.
So i am running into issues regarding Pump Failure for no reason at all at times where the icue just drops and all of sudden im pushing temps around 90 degrees, if im on a game it will go so slow and crash as it happens. Ive also noticed when returning to NMS its now doing this. I know the PC should run this game on max settings but i dont even have them on it its currently on High. I believe all drivers are up to date. Can i add the thing is loud aswell like the fans just seem so loud compared to previous build
FRACTAL NORTH TG XL GAMING CASE (BLACK)
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
ASUS® ROG CROSSHAIR X670E HERO (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
32GB Corsair DOMINATOR TITANIUM DDR5 6400MHz (2 x 16GB) KIT
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
Graphics Card Support Bracket
4TB CRUCIAL T705 GEN 5 M.2 NVMe PCIe SSD (up to 14,100MB/sR, 12,600MB/sW)
8TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
NOT REQUIRED
Braided Power Supply Cables
CORSAIR Premium Individually Sleeved PSU Cable Kit Pro (40 Series) - Black
CORSAIR ICUE LINK H150i RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
NOT REQUIRED
Microsoft® Edge
Year Standard Warranty (6 Month Collect & Return, 1 Year Parts, 3 Year Labour)
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Miscellaneous
PCSpecialist 2023 Holo Sticker Sheet
Welcome Book
PCSpecialist Welcome Book
Any advice to prevent this happening please send my way, again not very technical so dumb it down haha.
thanks
GetAttachmentThumbnail
Marksy68
Just there now again left the PC on to go to the kitchen came back 9 notifications on iCUE Pump Failure and RGB was off. What could it possibly be
Pump failure?
You'd need to RMA it, I would RMA the whole system as there could be damage to the CPU / motherboard if it's been used without an active pump.
Marksy68
Hi Thanks for the reply
I've been going over it a while with PCS and they offered to RMA, though was away for a while when we discussed in October though i have requested it now with them hoping to get this issue resolved.
Will update accordingly.
Ryan
