RAM Upgrade
TheVizGuy
Hi guys, i am thinking of upgrading my RAM to maybe 2 x 16gb, would my current spec be capable of that? More and more viz work (Lumion, Twinmotion, Unreal Engine, D5 etc) is making me think I should think about upgrading! Many thanks in advance.
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP, LHR
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
Firefox™
You could just add another 2 x 8Gb to give 32Gb, no need to swap it all out, no benefit.
If you go to your main PCS account, you can order another 2 x 8Gb in the upgrades section
TheVizGuy
Ahh ok that would be easier I suppose. In terms of installing, is this something I can potentially do myself?
Fitting RAM is really easy. One tip, though, if you're doing it for the first time: lie the PC down flat so you're pushing the RAM down into the slot. It's not necessary but it is easier if you're not used to doing it and knowing how much force to use.
That's a really good point, would fully agree with this, can take a bit of force to get the clips to click into place.
