The benefits from 4x8 single rank is literally the same as 2x16 double rank on top of that there is no option to get 4x8 3600 mhz, a kit like that is not available and combining 2 2x8 ram kits is not advisedDoes anybody know if PCS is still reducing the frequency on 3600MHz RAM that's in a 4x8 setup? I really want to benefit from the 4 single ranks but I wouldn't want to have the frequency reduced either.
PCS have never reduced speeds, if you order 3600 that’s what you’ll get. You need to be aware though that there may be instability.Does anybody know if PCS is still reducing the frequency on 3600MHz RAM that's in a 4x8 setup? I really want to benefit from the 4 single ranks but I wouldn't want to have the frequency reduced either.
just to clarify on this, instability happens if you combine Two 2x8 kits, as there is no 4x8 kit with 3600mhz speedsPCS have never reduced speeds, if you order 3600 that’s what you’ll get. You need to be aware though that there may be instability.
Thank you for the clarification, hadn’t actually checked that!just to clarify on this, instability happens if you combine Two 2x8 kits, as there is no 4x8 kit with 3600mhz speeds
Ahh I see, I vaguely remembered someone's post about PCS telling them 3600MHz caused instability, and that they reduced it to about 3444MHz which solved it?PCS have never reduced speeds, if you order 3600 that’s what you’ll get. You need to be aware though that there may be instability.
that could have been due to motherboard / cpu combo and that specific bin having stability issues with such fast ram. It is not what PCS does by default. Make sure you got good mobo and CPU that supports such speeds and you should be fine.Ahh I see, I vaguely remembered someone's post about PCS telling them 3600MHz caused instability, and that they reduced it to about 3444MHz which solved it?
That was us recommending it to 3553Mhz which often cures instability. It's not something PCS would do though, they'd just supply it as ordered.Ahh I see, I vaguely remembered someone's post about PCS telling them 3600MHz caused instability, and that they reduced it to about 3444MHz which solved it?
Oh I see! That's great news to hear, I asked previously on the text support and they didn't understand what I meant by ranks. I will switch to 2x16 immediately now and save myself some £.I have asked support personally to clarify number of ranks on those sticks. 8gb ones are single rank, 16gb ones are dual rank
Ahh! Understandable, my mistake.That was us recommending it to 3553Mhz which often cures instability. It's not something PCS would do though, they'd just supply it as ordered.
pretty sure it is both, it is literally the same ram just one has extra LED stuck to itOh I see! That's great news to hear, I asked previously on the text support and they didn't understand what I meant by ranks. I will switch to 2x16 immediately now and save myself some £.
Do you know if that applied to both the non-RGB and RGB 3600MHz RAM?
