MichaelJones
Back in September 2016 I bought a Cosmos laptop from PCS. It cost £700 and runs Linux Mint. It's been great. Occasionally it gets a bit hot and fan gets loud. But otherwise, it's fine. I now use it for personal email, web browsing, iPlayer, Amazon Prime movies, and once a week I run an awk script (on-line game... it's a long story).
I try not to use it for work (Remmina does not like connecting to our work servers), and I'm an Android phone and tablet user (SWGOH).
Brief specs:
Cosmos Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® CoreTM i7 Quad Core Processor 6700HQ (2.6GHz, 3.5GHz Turbo)
128GB SAMSUNG SM951 M.2, PCIe NVMe (up to 2000MB/R, 650MB/W)
8GB HyperX IMPACT 2133MHz SODIMM DDR4 (1 x 8GB)
NVIDIA® GeForce® GTX 950M - 2.0GB DDR3 Video RAM - DirectX® 12
I added an extra 250Gb SSD for my /home partition, and swapped out the DVD for another 250GB SSD for backup, music and picture storage.
Sadly I had to swap out the 128Gb M.2 PCIe to put into an old Win10 Dell XPS13 which I use for working from home (it's own M.2 PCIe failed), so now I use one of the Cosmos SSDs as my primary OS disk. Space is a little tight, but not unusable.
I am thinking of buying a new M.2 PCIe (maybe 250gb @ £35) for the Comos, and while the wallet is open, upgrade the RAM with another 8GB (~£40, but not sure this is a necessary upgrade).
Questions:
Anyone got suggestions for a good M.2 PCIe drive?
Should I look for exactly the same brand of RAM? Or will generic 'value' 2133MHz RAM be good enough? Or can I mix with 2400Mhz (looks slightly cheaper)?
Is there any (easy?) way to add a backlit keyboard?
Thanks in advance for any advice.
Brief specs:
Questions:
