RAID software or hardware?
AlanQ
I'm in the process of setting up my new PC from PC Specialist.
When we request RAID for a pair of disks, do we get hardware raid or software raid?
I have installed Ubuntu, and `gparted` is showing `/dev/sda` *and* `/dev/sdb` .
Can you post your full specs from the order page leaving out your windows key?
RAID is rarely recommended these days, it's very outdated technology and rarely makes sense anymore over more modern redundancy methods.
AlanQ
"*RAID is rarely recommended these days, it's very outdated technology and rarely makes sense anymore over more modern redundancy methods.*" -- now s/he tells me :D What should I have done instead?
Full spec:
FRACTAL NORTH TG GAMING CASE (WHITE)
Promotional Item
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
GIGABYTE X870 EAGLE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 32GB) KIT
RAID
RAID 1 (MIRRORED VOLUME - 2 x same size & model HDD / SSD)
CORSAIR ICUE LINK TITAN 360 RX LCD RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Miscellaneous
PCSpecialist 2023 Holo Sticker Sheet
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Trade Pack - New 2023
RAID 1 mirrors the disks: if one disk fails, I have time to replace it, and my data is safe.
So purely for redudnacy then?
A modern solution would be a: have an enterprise grade NAS drive in the build itself (WD Red Pro or Seagate Ironwolf Pro). This limits failure rates significantly plus has far higher endurance. I would contact PCS and see if they’ll let you swap those drives for Ironwolfs
Then have your redundancy set up on a proper NAS drive on the network. That can then be accessed anywhere on the network or internet if required.
Backup - daily and automatically. That's what I do. It's all about risk, and the risk of a drive failure these days is very small. RAID was never a home technology, it was designed for server farms. It was never designed for NVMe drives either - they are hardly inexpensive.
