Quick Spec Check. TIA :)
Slurpak
Ordering in a month or so, and playing around because I can't wait!
Purpose - Gaming
Budget - £1500 (cheaper is possible, but more concerned about getting most bang for buck)
NZXT H700i MID-TOWER GAMING CASE (WHITE)
Intel® Core™ i7 Quad Core Processor i7-7740X (4.3GHz) 8MB Cache
ASUS® ROG STRIX X299-E GAMING: ATX, USB 3.1, SATA 6 GB/s, WIFI - RGB Ready
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
1st Hard Disk
480GB KINGSTON UV500 2.5" SSD, SATA 6 Gb (520MB/R, 500MB/W)
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
NOT REQUIRED
INTEL SOCKET 2011/2066 STANDARD CPU COOLER
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
Genuine Windows 10 Home 64 Bit - inc. Single Licence [KK3-00002]
NO RECOVERY MEDIA REQUIRED
Price £1,556.00 including VAT and delivery
Thanks in advance for all your feedback :)
polycrac
Super Star
Hi Slurpak,
First, I'd suggest looking at the Z370 and Z390 motherboards - they open up options like the i7-8700 (k) and I9-9700 (k). You can find them here:
https://www.pcspecialist.co.uk/computers/intel-z370-pc/
Or here, for overclocked:
https://www.pcspecialist.co.uk/computers/intel-z370-overclocked/
I'd suggest a M.2 NVMe drive instead of the SSD you picked - they are a lot faster and something like the Samsung 970 Evo or a WD black would work well for this build.
The standard Intel cpu cooler is said to be relatively noisy, so you might want to look at replacing it.
You could also get more milage from faster RAM.
As for the graphics card - that really depends on what monitor you are using - HD? 1440p? Refreshrate?
I know nothing about cases, so I left that as it was, but here is where I would be looking with your budget (assuming a standard full HD monitor):
Overclocked CPU
Overclocked Intel® Core™ i7-8700K Six Core (3.7GHz @ up to 4.8GHz)
ASUS® PRIME Z370-P II: ATX, LGA1151, USB 3.1, SATA 6GBs
1st Hard Disk
500GB WD Black™ M.2 NVMe PCIe SSD (up to 3400MB/s R | 2500MB/s W)
NOT REQUIRED
Price £1,576.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-overclocked/U97KHms99P/
Final caveat - depending on your current monitor, you might want to change GPU and if looking for a new monitor within the same budget, you might want to swap some stuff around...
polycrac
Super Star
... to something like this (with all the extras dialed back a bit to allow for a better GPU) if you are gaming at 1440p:
GAME MAX FALCON BLACK GAMING CASE (RGB LED)
Intel® Core™ i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
8GB NVIDIA GEFORCE GTX 1070 Ti - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
1st Hard Disk
250GB SAMSUNG 970 EVO M.2, PCIe NVMe (up to 3400MB/R, 1500MB/W)
FREE Assassin's Creed: Odyssey with select SAMSUNG NVMe SSDs!
NOT REQUIRED
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler
Price £1,543.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/g8dK4465wz/
a lot depends on what games you play and what monitor you play them on!
Playing around with the configurators and components is fun, but honestly no point planning the spec from a practical point of view as pricing, stock, availability, etc will all be different. :)
What you choose now may not be available, and if it is available it may not be the best or best buy any more.
What monitor are you using?
