Jin Comrade
Hi !
I have an acer laptop "5315"
"Quick SPEC"
3gb DDR2 RAM
250GB HDD
OS: WIN 7 Home basic
Intel Core 2 Duo T5550
I was recently updating the BIOS as I felt hard drive instability ( I might be wrong on that). Anyhow it went bad, screen froze and that was end of it. When I plug in the charger even the lights wont turn on (completely dead).
Brief explanation has been given, so now the question.
If I buy a new motherboard and replace it, will it fix the problem ?
Thank you
"Quick SPEC"
3gb DDR2 RAM
250GB HDD
Thank you
