Question regarding the motherboard software for gigabyte motherboard
So I’ve got a question regarding the motherboard software, especially for gigabyte motherboards. My question is, is the software needed for my PC or will be fine to leave it uninstalled as I uninstalled it a while ago due to having to issues with it but can no longer control the RGB lights for my fan as I would use the gigabyte control centre. Does anyone know any other way of controlling RGB in my PC without the need of the motherboard software as I heard it’s not recommended to have motherboard software installed as it causes bloatware, which I’m not sure if this is true or not. Would be much appreciated if anyone knows any other software for RGB that would work with my PC.
As already stated here: https://www.pcspecialist.co.uk/forums/threads/gcc-driver-updates.100428/#post-766941
With GCC or Asus Armoury Crate, they cause more issues than they address, the idea is if you want to sort your RGB, you install it and set that, then uninstall it.
Or you can use something like SignalRGB or OpenRGB to control RGB without having to install those garbage softwares.
Ah, I didn’t see that you posted it in the other thread. I will try SignalRGB. Will this happen to conflict with iCue by any chance as my PC has 3 Corsair iCue fans.
