I just order a Defiance III 15" with the following specs :
Chassis & Display Defiance Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™ i7 Quad Core Processor 6700HQ (2.6GHz, 3.5GHz Turbo)
Memory (RAM) 16GB HyperX IMPACT 2133MHz SODIMM DDR4 (2 x 8GB)
Graphics Card NVIDIA® GeForce® GTX 1070 - 8.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
Memory - Hard Disk NOT REQUIRED
M.2 SSD Drive 256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
Memory Card Reader Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor 1 x 230W AC Adaptor
Power Cable 1 x 1 Metre European Power Cable (Kettle Lead)
Sound Card Intel 2 Channel High Def. Audio + MIC/Headphone + SoundBlaster X-Fi MB3
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® AC-8260 M.2 (867Mbps, 802.11AC) + BLUETOOTH
USB Options 3 x USB 3.1 Type A, 2 x USB 3.1 Type C AS STANDARD
I wonder which Clevo chassis it will be. When I ask the PCS customer service, they indicate me it will be a P65XRP6 chassis. And they also indicate me it will 2.5cm thickness and 2.5kg (excluding the charger). But when I look the reviews, it seems to be a P65XRS
Can someone with the same specs could confirm me which chassis it will be. And, if possible, with pictures. It will be great
Thanks in advance,
cedrixman
Thanks in advance,
cedrixman
