Ah okok i tried to give as much detail about the problem, removing ram caused beeps. and reseating my gpu also caused them. thank you~!They'll likely try to replicate the BSOD and try to find what causing the issue. Then if it's software reinstall windows+drivers to see if that helps and if it's hardware related they will replace the hardware with a new piece
