skipper8472
Hi i be for i do buy a new pc i want to see if i can overclock this pc first. As alot of people i dont no what to do. My PC is.
Processor: Intel Core Quad CPU Q6600 @ 2.40GHZ 2.40GHZ
Installed Memory (RAM): 4GB DDR2
Motherboard: Asrok P43DE
System type: 64-Bit Windows 7 pro
Graphic card: XFX 5770
PSU 1000Wat
Option in side bios.
OC Twaker
DRAM Frequency [AUTO] Options
333MHz DDR2 667
400MHz DDR2 800
533MHz DDR2 1066
Ratio Cmos Setting 9 [9]
Intel(R)SpeedStep(TM)teck [AUTO] Options
Disable
Enable
Auto
OverClock Mode [AUTO] Options
Auto
Manual
IOT
Optimized
CPU Frequency [MHz] [266]
PCI Frquency [MHz] [1]
Strap FSB to MCH [AUTO] Options
800
1333
1600
Is there anything i can alter to over clock and with out over heating anything by altering these values?. Ive not done so yet apart from setting it to IOT mode in the overclocking option mode which means Inteligent Overclocking. I just want to see if i can make it more overclocked doing it manualy.
Thanks for any info and if you need any more info on my bios please ask.
PSU 1000Wat
OC Twaker
333MHz DDR2 667
400MHz DDR2 800
533MHz DDR2 1066
Disable
Enable
Auto
Auto
Manual
IOT
Optimized
800
1333
1600
